Dos and don'ts
Aucune réponse à ce sujet
#1 Mike118
  • 10 334 messages
Posté 03 février 2020 - 09:31
Vigibot Dos and Don'ts
Dos :
  • Use raspberry pi fish eye camera ( for a better view)
  • Use a rasperry pi camera with Infrared cut filter to have great colors during day time
  • Try to follow the standard default configuration as much as possible
  • Ask help to understand how to configure your robot if needed
  • Use arduino board to make your custom code
  • Share about your needs and make suggestions => We are always improving the website
  • Optional : Use a camera with amovible ir cut filter if you want that your robot see in the dark like this raspberry pi camera
  • Optional : Use a 270° servo for the pan head servo
  • Optional : Share your robot to registered members => It is funnier together !
Don'ts
  • Do not use cheap 360° endless servo to drive wheels. (Velocity control on cheap endless servo is bad ... You will have troubles to drive your robot ), prefer use a DC motor and a motor driver.
  • Do not use usb camera use raspberry camera with CSI Ribbon for best performance (except for special things like thermal camera / depth camera but that are not supported yet)
  • Do not modifiy the nodejs client except if you know exactly what you are doing (in this case, please ask before we will help you)
